Cart Module Questions
  • Thank you received: 24
13 years 5 months ago #96951
All right i managed to do several things, first thanks to widgetkit i managed to display the cart ina modal window without problems, but the url in php you gave me leads to a kind of customer cart or multicart, you can put name to the cart an add to wishlist or convert cart to wishlist, but you cant continue to chekout.
What i really would like is to be able to display hikashop cart module in a modal window but i cant get the correct url to do that.
Last edit: 13 years 5 months ago by condorazul.
13 years 4 months ago #97269
The cart module view is in "product / cart".
To call this view, the code:
<?php
if(!defined('DS'))
	define('DS', DIRECTORY_SEPARATOR);
if(!include_once(rtrim(JPATH_ADMINISTRATOR,DS).DS.'components'.DS.'com_hikashop'.DS.'helpers'.DS.'helper.php')){
	echo 'This module can not work without the Hikashop Component';
	return;
$js ='';
hikashop_initModule();
$config =& hikashop_config();
$module_options = $config->get('params_'.$module->id);
if(empty($module_options)){
	$module_options = $config->get('default_params');
foreach($module_options as $key => $option){
	if($key !='moduleclass_sfx'){
		$params->set($key,$option);
foreach(get_object_vars($module) as $k => $v){
	if(!is_object($v)){
		$params->set($k,$v);
$params->set('cart_type','cart');
$params->set('from','module');
$html = trim(hikashop_getLayout('product','cart',$params,$js));
if(!empty($html)){
<div class="hikashop_cart_module" id="hikashop_cart_module">
<?php echo $html; ?>
</div>
<?php }
is used. So you can maybe create a view, use this code inside and call the created page in your link.
13 years 4 months ago #97794
Ok finally i managed to do it and it was much simplier than that.
the only thing we have to do is add in the href="#hikashop_cart"
so the cart is displayed!!!
