Add to Cart module not updated with Ajax ?
13 years 5 months ago #97632
Hi guys , why the hikashop cart module does not auto update itself via Ajax when a product is added to cart unless you refresh the whole page. I thought Ajax was implemented.
13 years 5 months ago #97668
This is probably a cache issue, try to disable all the cache:
www.hikashop.com/fr/support/documentation/faq.html#cache
You can to turn off the option "Use AJAX when possible for add to cart button" in Config > Main > Advanced
