Front page problem
13 years 4 months ago #98797
Before I begin sorry for this but I can't see the right way to start and also somehow search function doesn't return me answer :(
I installed Hikashop on Joomla 2.5 (latest version) and created categories.
For test I created one product and now I have difficult to show it on fron page.
Here are printscreen:
What am I doing wrong?
Kind Regards
HIKASHOP NOOB :(((
  • Thank you received: 4077
13 years 4 months ago #98981
The white popup with the content "3 Da..." is not logical.
You should see the content of the popup because there is a javascript which should copy the html content in the parent parent and close the popup.
So, I think you have a javascript error in your page.
Which version of HikaShop are you using ?
Would it be possible to have a backend access to your website in order to test it directly ? (you can send us such private information by private messae or via the contact form (indicating the url of this thread)).
Thanks,
The following user(s) said Thank You: Mitjag
13 years 4 months ago #99123
Hi Jerome,
Yes indeed this white screen was strange also for me.
As for backend access. I just started to create this page for e-commerce and there is only:
- Joomla 2.5.9
- Hikashop (latest version 2.1.2
- only think additional installed is JCE Editor 2.3.2.4
I will send you login details to computer.
Thank you for your help.
Mitja
13 years 4 months ago #99199
Can you enable the Joomla debug mode, and set the error reporting level to maximum, try to select again a category and see if an error message is displayed ?
13 years 4 months ago #99222
Thanks for the access.
We made a new package with a patch for this problem. You can re-download HikaShop and update your website.
13 years 4 months ago #99323
Thank you very much. I will test it and post results.
Edit: patch is working excelent. Thanks you again.
Last edit: 13 years 4 months ago by Mitjag.
Time to create page: 0.708 seconds
