breadcrumbs from related products and best sellers
13 years 3 months ago #107196
breadcrumbs appear to be working as expected when I navigate from from menu
home -> product -> category A-> product A
on my product detail page, I've published "related products", if I select a product the breadcrumb becomes
home -> product B (whatever I selected)
how do I tell the breadcrumb to retain the structure as shown from navigation?
thanks
  • Thank you received: 14209
13 years 3 months ago #107229
What are the links that are generated in both cases for the product ?
In think that you need to select your "product" menu in the "related products" module's "menu" option via the menu Display->Content modules of HikaShop.
13 years 3 months ago #107263
yeah, I see how that changed the breadcrumb. The way I see the breadcrumb working is showing you more a browse history of where you are and where you came from, is there a way to have it more show as a hierarchical representation of where your product is?
Way it seems to work:
click product, click category A, click product A, click related product z (in category B)
breadcrumb = home > products > category A > product A > product B
desired outcome, representing product B heirarchy in the store
breadcrumb = home > products > category b > product B
thanks
13 years 3 months ago #107278
That's indeed how it works.
To have it like you want you would have to change the line:
$related = JRequest::getInt($related_sef_name,0);
$related = 0;
in the file components/com_hikashop/views/product/view.html.php
