Minicart module stay on same page and position?
13 years 2 months ago #108733
I got the following setup:
HikaShop Starter 2.1.3
Joomla 3.1.1
cartmodule with show minicart
hikashop configuration > main > cart > always stay on same page.
It is doing what is suppose to do so therefore there is no bug! But I would love to add some functionality to it. What it does now is reload the page and it stays on the top of the page. The problem for some pages is that those are too long. With the product tag insertion system and some custom styling it is easy to create a nice page for your visitors to scroll through your products and immediately add them to their cart. But it is highly annoying to keep scrolling back to the position you where on the page.
Easy Solution: Is to create a menu with buttons to all products but this will maybe work with some design but it will not work with most designs.
So does anyone know what the professional solution to this problem would be? All responses will be greatly appreciated.
Last edit: 13 years 1 month ago by loginsecure.
  • Thank you received: 4077
13 years 2 months ago #108779
If you use the "ajax" mode, the page will not be reloaded so the scrollbar will not move.
The following user(s) said Thank You: loginsecure
13 years 2 months ago #108879
Hello Jerome,
Thank you for your solution. It works even better as I was hoping. I knew this function was present I dont know why I used it. Thanks for pointing it out.
For everyone else who is reading this and have some difficulties the "Ajax" mode is located in Hikashop configuration > Advanced Settings.
In here select for the option, "Use AJAX when possible for add to cart buttons", Yes.
Greetings
