help me. modul carousel not work...
13 years 1 month ago #113760
please help me!. carousel not working .
this not slide automatic and not slide if i click button next or perivious in carousel button
this my link grosircibaduyut.p.ht/
and this pictures capture configuration .
  • Thank you received: 14207
13 years 1 month ago #113834
This is because of the improper use of jquery from your template which creates a javascript error, preventing the carousel from being initialized properly on the page.
You will have to install the jquery easy plugin ( extensions.joomla.org/extensions/core-en...jquery-scripts/18327 ) and configure it to avoid the conflict and that should then work properly.
13 years 1 month ago #113851
thanks nicolas.
but i not understand how to work this plugin . i beginer. and i can find the problem . sorry .
  • Thank you received: 403
13 years 1 month ago #113879
You may understand that we already have a lot of work on our own plugin so we can't really take the time to help you with this.
You should take a look at some tutorial or ask on the jquery easy plugin forum ;)
13 years 1 month ago #113941
It's quite simple actually.
Simply install the plugin on your website, enable it and configure it to fix jquery on the frontend via the joomla plugins manager and voilà.
Also make sure that you turn off your joomla/template cache or you might not see the change.
Time to create page: 0.451 seconds
