Problem with vote and comments
13 years 1 month ago #117211
-- url of the page with the problem -- : www.ta-ergaleia.gr -- HikaShop version -- : 2.2.0-- Joomla version -- : 2.5.14
-- PHP version -- : 5.3.23
-- Browser(s) name and version -- : all broswer
-- Error-message(debug-mod must be tuned on) -- : an error has occured
hello,
i have a problem with the vote & comments.Does not work.
www.ta-ergaleia.gr/index.php/δοκιμές-τεστ.html
13 years 1 month ago #118060
But it seems to be working fine through this page can you disable your SEF modules and test it again ?
Last edit: 13 years 1 month ago by Mohamed Thelji.
13 years 1 month ago #118310
if you try to see the stars of voting in google chrome...you cannt! doesnt appear
13 years 1 month ago #118320
There is a javascript error in your website which does not look to depend on HikaShop but on something around mootools.
The error affect the "domready" event of mootools so the vote system is not initialized properly on google chrome.
I don't understand why the hikashop javascript file is include before mootools. Maybe it is the source of your problem but I am really not sure. After that I see that you have a image slider which uses jQuery. There is the noconflict so it shouldn't create problems but you can try.
13 years 3 weeks ago #119374
i disable image slider but the problem not fixed!
ie and mozilla works fine...
Last edit: 13 years 3 weeks ago by goforbet.
13 years 3 weeks ago #119384
The javascript of the slider is still include in your website.
The order of the javascripts is still weird. HikaShop should be listed before mootools.
And there is still an error in your website
Uncaught TypeError: Object 1 has no method 'apply' - mootools-core.js:375
And as you can see, it come from the mootools library so I don't know what we can do in the HikaShop side.
13 years 2 days ago #122462
i am trying to solve the problem and i cant.can you help me?
and why is problem to google chrome and not to mozila or ie?
Last edit: 13 years 2 days ago by goforbet.
  • Thank you received: 14206
13 years 1 day ago #122603
Try to install and configure the extension jquery easy it often helps solving conflicts between jquery and mootools:
extensions.joomla.org/extensions/core-en...jquery-scripts/18327
13 years 1 day ago #122724
i full uninstalled the image slider but the problem still repoain. yesterday i used the jqery easy when i was tryind to find a solution but nothing happen. everythings works fine to mozilla and ie and stars doaesnt appear to chrome
13 years 1 day ago #122742
For what I see, the order of the javascript inclusion is much better.
But the initial link is not working so I can't see a page with the vote&comment.
Last edit: 12 years 11 months ago by Jerome.
12 years 11 months ago #123095
www.ta-ergaleia.gr/index.php/sompes_ksil...zakia_thermansi.html
try to see this page with ie-mozilla and with google chrome.
if i understand you. my english is not very well,sorry
12 years 11 months ago #123102
I am sorry, it is not possible to make any kind of debug in your website.
The error is not made by HikaShop but there is a javascript error, I think generated by
var flashvars = {};var params = {menu:"",wmode:"transparent",allowscriptaccess:"always"};var attributes = {};swfobject.embedSWF("http://www.ta-ergaleia.gr/gantia.swf", "flashid", "218", "180", "9","http://www.ta-ergaleia.gr/modules/mod_swfobject/lib/expressInstall.swf", flashvars, params, attributes);
jQuery(window).load(function() { var $ = window.jQueryNivoSlider || jQuery;
Because if I put a breakpoint before, I get it but if I put a breakpoint after, I don't have it (which means that there was a javascript error).
This javascript error made that our voting library is not called and can't display the vote system.
Sorry but we can't give you more information about it.
12 years 11 months ago #123108
i just unistall swf , if this is the problem but another time that star not displaying to google chrome..
this javascript error why is problem to crome and not to other broswers?
  • Thank you received: 403
12 years 11 months ago #123191
There is an error in the code which is detected by chrome and block the script execution.
You should try with another template or try to find the code jerome pointed in order to remove/fix it.
You can also try to google the error code in chrome, it appears to be a frequent error so far.
Uncaught TypeError: Object 1 has no method 'apply' (in mootools.js)
12 years 11 months ago #123295
i told the creator of this template , what you said me , and he fixed my problem,i dont know how....:-)
thanks a lot for your help...
i think the topic must be close...
thanks again
everythinks works fine
