How to create sets of products
13 years 3 weeks ago #118996
-- url of the page with the problem -- : www.todo-aerografia.org (site for testing)
-- HikaShop version -- : 2.2.0
-- Joomla version -- : 2.5.14
-- PHP version -- : 5.3.27
I'm trying to create sets of products as described hereunder:
set #1:
Obligatory products of the set:
product #1 (price: 73.55€)
product #2 (price: 61.98€)
Optional products of the set:
product #3 (price: 10€)
product #4 (price: 10€)
I have used OPTIONS to create the set but I have two issues I'm not able to solve:
1) I need to keep the obligatory products fixed (unchangeable) but with OPTIONS I can't do it.
2) The price of the set is shown as free (gratis) and I need to show the sum of the two obligatory products (135,53€)
Is there some way to do this?
Thanks in advance for your help
Walter
13 years 3 weeks ago #119070
You can use options+variants in order to have some "fixed" options, like in our demo website
demo.hikashop.com/index.php?option=com_h...ow&Itemid=91&lang=en
About the product price. It does not include the price of the options. So if the product does not have a price, it will display this "free" price.
Do not forget to add the option in the HikaShop configuration in order to link the options with the product. Otherwise the user would be able to remove a "fixed" option from his cart.
13 years 3 weeks ago #119096
Hi Jerome,
The problem is that the price of the set can't be zero (free) and this is what shows in the products listing.
What I'm trying to get is a set of products composed by product A and product B, and the price to be shown in the products listing is the sum of A and B. Is there a way to do this?
13 years 3 weeks ago #119136
By default we don't manage that. You will have to edit the view "product / listing_price" to get the options of the product, get the price of the options and add this price to the current product price (when the layout type is listing).
It require good php knowledges.
Another solution could be to duplicate the option products in another category, for example, "options" and set their prices to 0. Then change the default price of the set to the price of product A + product B.
Time to create page: 0.382 seconds
