Products not visible in catagorie's
11 years 11 months ago #54156
I have a strange problem where i cant find the solution for.
After creation of the product pages and linked them to the catagory the product is not visible on the frontend.
When I open the catagory the product is not visible.
On the frontpage is the item visible in the HikaShop Content Module.
What do i mis?
the link to the page is: vjvmaguzijn.nl
  • Thank you received: 13107
11 years 11 months ago #54232
I can see a product in your products listing:
vjvmaguzijn.nl/hic/categorie/12-healing.html
Did you find out ?
If you're talking about other products, then make sure that they are added to the correct category and that they are published.
