Using Badges per product
13 years 11 months ago #63358
I just discovered this marvellous new feature : "Badges" :) :)
Is there a way to select this per product (I can only select per category)
Also if it would be possible to select the language per badge that would be great...
It is also strange that I was not able to select a discount that I created before (and yes .. that discount was activated)
But not showing in the listing of the 'badge' feature. (Bug ?)
kind regards,
Jan
13 years 11 months ago #63375
I guess by creating a category "rebated products" I can make a selection of the products that I give a reduction...
  • Thank you received: 14190
13 years 11 months ago #63543
Indeed the selection of discounts doesn't work properly. We've fixed that and published a new build for that. You can download and install again HikaShop to fix the problem.
That will aslo add the integration files with falang/joomfish so that you can translate the badges for the different languages of your website via the interface of falang/joomfish
13 years 11 months ago #63592
I updated to the latest version. com_hikashop_business_1.6.0_2012-09-03
but I don't see anything changed... ???
1) the discount is still not visible
2) No idea where the Falang translation can be ?
But still this is a great feature !
Hope you can fix these small issues.
Br
Jan
13 years 11 months ago #63844
1. It's working fine for us.
You can try it on our demo website.
2. Go in the Components>Falang>Translations menu and edit the badge there and you will be able to change the name and the image for each language.
