Add to cart popup nav bars and size problem-SOLVED
13 years 11 months ago #64189
I have a problem with the add to cart button, the popup shows navigation bars and the size of the popup is to large.
mercando.algom.co/index.php/mercar
Last edit: 13 years 11 months ago by amin.gomez.
  • Thank you received: 14190
13 years 11 months ago #64253
That comes from the CSS:
body {
min-width: 960px;
.rt-container {
margin: 0 auto;
width: 960px;
which is in the CSS file mercando.algom.co/libraries/gantry/css/gantry.css of your template.
If you remove that CSS, it will display fine.
13 years 11 months ago #64367
Hi, if i remove that code from the css, it works, but it affects the overal layout of the tamplate (as in the image), all the template align to the left. Can you help me with this?
13 years 11 months ago #64445
can somebody help me?
13 years 11 months ago #64501
hi, the rockettheme team help me with this, here is the their answer:
1.
Open component.php in your template folder
Find <body> and change it to
<body style="min-width: 200px">
Save that.
2.
Add this to your css
body > #rt-main div.rt-container { width: auto;}
3.
Clear your browser-cache ...
....and it worked perfect
The following user(s) said Thank You: djundi
