Pagination not showing in products listing
13 years 4 months ago #97480
I have searched all forums post related to columns.
I can't get this site to present properly.
www.indoelements.com/gear
Attached is the file of the settings being used.
Let me where I can send access via PM to if more details are needed.
K
13 years 4 months ago #97496
The screenshots that I'll need would be the screnshots of your product listing configuration page, but you can also send me a temporary access to your back end through PM :).
13 years 4 months ago #100969
The problem is coming from your template configuration, I tried it with your "protostar" template and it seems to be working fine.
13 years 3 months ago #101883
I'm getting no response from Joomlart on a solution. Is there any other way to make Hikashop perform as it should even though there seems to be a problem with the Template. Joomart and Hikashop are supposed to be compatible?
  • Thank you received: 14190
13 years 3 months ago #102074
I checked your website www.indoelements.com/gear and I can see the pagination at the bottom:
Time to create page: 0.342 seconds
