minimum order amount
13 years 4 months ago #99832
How to set a minimum order amount?
Vero
13 years 4 months ago #99923
You can set a minimum price on all the shipping methods. And change the notice message to display that the order amount is not to low.
13 years 4 months ago #99972
I don´t understand. I want the minimum order 5euro, and if is more than 30euro, shipping is free.
Where are those options? When I has VM shop, there was an option: minimal order amount.
Vero
  • Thank you received: 14190
13 years 4 months ago #99995
It's automatic.
You create two manual shipping methods:
one with a minimum price of 5€ and a maximum of 30€ with the price you want for the shipping.
a second one with a minimum price of 30€ with a price of 0€
Then, the system will display the corresponding shipping method based on the price of the cart and it will display an error message when no shipping methods are found for the cart.
