Problem with backend translatuioin
13 years 3 weeks ago #108957
I have a problem with a specific backend translation.
All labels with the languahe string "HIKASHOP_YES" and "HIKASHOP_NO" wil be no longer translated in any language.
I have no idear where it comes from.
See the attachment.
Thanks in advance,
René
Last edit: 13 years 3 weeks ago by Rebo2k.
  • Thank you received: 14101
13 years 3 weeks ago #108971
It doesn't look like a translation issue but rather like a template CSS issue.
Are you using the default template of the backend of Joomla ? If not, try to switch back to it and it should display fine again.
The following user(s) said Thank You: Rebo2k
13 years 3 weeks ago #108999
Thank you for directing me to the right direction :)
I switched the backend css in the configuration module from Hikashop, from custom to default, saved it and there was no result.
Switched it back to custom and saved it again, and the problem is solved.
Thanks again.
