Display products or products in category
13 years 4 weeks ago #116959
-- url of the page with the problem -- : lillebygrillen.se.preview.citynetwork.se/index.php/features
-- HikaShop version -- : HikaShop Starter: 2.2.0
-- Joomla version -- : Joomla! 2.5.13 - Template Fresco ( rocket theme )
-- PHP version -- : 5.3.10-1ubuntu3.7
Hi !
I'm new to the hikashop , normaly i use Virtuemart.
I have chosen "product page" in the menu type and chosen two products but it ony shows one. i want to display it as it is , a new product gets under the older one Like this site www.lillebygrillen.se/grill/
also is there any funktion that can display all the products in a category as the site www.lillebygrillen.se/grill/
13 years 4 weeks ago #116961
Regarding the products that will be displaid through your content menu, you'll be able to choose these products by using the "Associated category" option of your content menu.
13 years 4 weeks ago #116964
i have chosen two files , it only show one.
i hope i understood you.
13 years 4 weeks ago #116981
I'll give you more precision :) :
- Create a category through "Hikashop->Product->Category"
- Go to each product page that you want to be displaid through your product listing "Hikashop->Product->'YOUR PRODUCT'"
- Add your products to this category
- Go to your content menu's page through "Hikashop->Display->Content menus"
- Set the Associated category option to the category that you created
Then that should do the job.
Last edit: 13 years 4 weeks ago by Mohamed Thelji.
13 years 4 weeks ago #116988
Cool ! :cheer:
last question i have to have the Characteristics on the first page when you enter lillebygrillen.se.preview.citynetwork.se/index.php/features
is that possible in hikashop ?
  • Thank you received: 403
13 years 4 weeks ago #117003
Hi there,
This is not possible in hikashop yet, it would require some huge modifications and if you have too many product the process would be too long.
However, you can still ask on our commercial jobs forum for someone to do it.
13 years 3 weeks ago #117030
is there really no way ?
if i chose in the menu Products listing the product is showing in the first page with the Characteristics
is there no way to show 2 products ? even if i upgrade the hikashop ?
13 years 3 weeks ago #117037
Maybe I didn't understand then.
What do you mean by characteristic? It's the one you added to you product to create a variant? If so, you cannot display it in a product listing.
So there comes my second question, what are you talking about when you say "product listing", you mean "product page" right? If so, that explain why you can see the characteristic.
13 years 3 weeks ago #117052
sorry my bad
i meant "Product page" if i choose Product page in menu type i get the details i need for the page.
but it only displays one product even if i chose two.
13 years 3 weeks ago #117217
There is a mistake in this product selection.
The product page is A product page, it means that you can only display one single product on the page.
If you want to display several products, at this moment you want to compare them. So you have to use a "Comparison page" and not a "product page".
We will fix this product selection problem as soon as possible.
