product images size problem
12 years 11 months ago #123808
-- HikaShop version -- : 2.2.0
-- Joomla version -- : 2.5.14
I need the images on the product listning page to be 150px. On the product detail page I need a bigger image namely 400px
How do I set this ???
If I set thumbnail to "yes" it load also the small image from the productlistning page onto the product detail page..
If I set thumbnail og "NO" I get a bigger images in the detail page, but now there is no image in the product listning page ???
Please advise...
regards
Bison
12 years 11 months ago #123816
www.hikashop.com/support/documentation/5...fig.html#main_images
There is option for the sizes.
12 years 10 months ago #126905
I have a web designer using Joomla and HikaShop designing a site for me. In one category of products the images are the correct size on pages 1 & 3 but on page 2 the images are very small almost thumbnail size. These same images are the right size on other category pages. Do you know what the problem might by?
12 years 10 months ago #126932
Can you give us a link to your website to see the problem ?
12 years 10 months ago #127036
The link is www.tangyweb.com.au if you then click on All products and then Baby Basics the images are the right size on page 1 & 3 but on page 2 they are very small. These same images are elsewhere on the site such as the category daytime or just for girls and are the right size in these categories.
Also can I change the number of products on each page from 25 to 24 with the version of hikashop being used so that the columns are even
Thank you
Last edit: 12 years 10 months ago by hopeful.
12 years 10 months ago #127061
Do you have any kind of cache system ?
The problem is that, I can reproduce your problem but if I change the pagination quantity (showing 50 items and not 25), all images have the right right.
So I am supposing that you have a cache system which has cache the second page of the listing with wrong image size.
12 years 10 months ago #127065
Thank you I will give that information to the site builder, can you also tell me if I can change the number of products on the page to 24 instead of 25? This will make the columns even
Thank you
12 years 10 months ago #127093
Yes you can change the number of products to 24 in the options of your menu / module.
12 years 10 months ago #127247
Hi there
For me ,i often do the image issues using an image zooming section,which supports to zoom in and out the image size effectively .
But i know there are many third party program for image size .SO I want to know is there any software that can do the image size issues offline?
Last edit: 12 years 9 months ago by Jerome. Reason: removing spam links
12 years 10 months ago #127250
If the problem is caused by a cache system, can you explain to me what a cache system is and is it part of the web building system?
Thank you for all your help I have managed to fix some other problems with your instructions
The following user(s) said Thank You: Xavier
12 years 10 months ago #127291
A web cache is a mechanism for the temporary storage (caching) of web documents, such as HTML pages and images, to reduce bandwidth usage, server load, and perceived lag. A web cache stores copies of documents passing through it; subsequent requests may be satisfied from the cache if certain conditions are met.
To disable the Joomla cache, you have to go in the global configuration and disable it, you have too to unpublish the joomla cache plugin. It's possible that your template or other extensions manage the cache too on your website, thanks to disable them.
12 years 10 months ago #127437
If I disable the Joomla cache will it affect anything else on the website or is it OK to disable the Joomla cache?
Also can I change the word "cart" on the home page to a picture of a shopping bag and use the text "shopping bag"?
If yes how do I do this?
12 years 10 months ago #127455
Disabling the Joomla cache will not have bad side effects. It will allow components like HikaShop to be called each time in order to always have a "valid" (fresh ?) content.
For your cart customization. The best is to put a suffix in your Joomla module and use some CSS like we done for our demo website (for the image). The title is just an option of your module.
12 years 10 months ago #127588
Thir is a different problem
I have a pop-up window that pops up when an item is added to the cart that says "item successfully added to cart" but when an item is deleted from the cart the same window pops up to say an item has been added to the cart. How do I change this so the pop-up says an item has been deleted from the cart in this case?
  • Thank you received: 14189
12 years 10 months ago #127611
There is no popup which displays when a product is removed.
It's probably an issue with displaying the same page again which already contains the fact that the popupis being displayed when the page loads.
You should try to turn on the "Use AJAX when possible for add to cart buttons" option of the configuration. That should avoid the issue in most cases.
12 years 10 months ago #127688
I wanted to change the order of the fields on the registration form and managed to do this but the order doesn't change on the printed shipping and billing address. Can you tell me what I do to change the order of address and postcode on the shipping and billing address?
12 years 10 months ago #127707
For that, you need to edit the files "address_template" via the menu Display>Views and change the order of the tags in the files.
The following user(s) said Thank You: hopeful
12 years 10 months ago #128943
Thank you for all your help lately.
Two more queries, the first I would like to show quantity of products available on the internal page, where customers choose option for characteristic and quantity they are after but I don't want the quantity available on the category page before they choose option. How do I show this?
Second query, on my website when you click on "All Products" more categories are shown on the all products page, I would like these categories to show on all the category pages on the site so customers can easily change categories without having to go back to the "All Products"page. Is this possible and how do I do this?
I have included a link to my website for you to have a look www.tangyweb.com.au
Thank you
12 years 10 months ago #129063
1. You can add a simple css property: .hikashop_products .hikashop_product_stock_count{ display: none;}
2. What can be done is to use a module, just add a categories listing module and display it before the content.
By this way it will be always displayed.
12 years 10 months ago #129142
Thank you for your help
Can you tell me, I would like to change the text on the home page from "cart" to "shopping bag" and add a picture of a shopping bag. Can I do this?
Also when I click on "checkout" on home page it goes to a page called "product category" I don't know what this page is, how can I get rid of this page and have checkout go to checkout even when the checkout is empty. www.tangyweb.com.au
please look at this on my homepage so you know what I mean. If you are ordering and go as far as paypal and then decide to cancel and go back to the site you also get sent to this product category page.
Last edit: 12 years 10 months ago by hopeful. Reason: add a question
Time to create page: 0.134 seconds
