DIV doesn't work on product display.
12 years 10 months ago #129578
I'm having trouble with the DIV product display.
As you can see, DIV works fine on category display ( www.tri-mans.com/index.php/hikashop-menu...ory/20-rangement-alu )
But, when I'm using the same settings for product display the result is quite different on the product listing ( www.tri-mans.com/index.php/hikashop-menu...tegory/13-value-line ) or the product page itself ( www.tri-mans.com/index.php/hikashop-menu...-technique-abs-grise )
Still, when I'm selecting a particular picture, the preview works just fine and the quality is perfect.
I'm using DIV display in 300x188 for all the category picture. Same settings for the product display, but with better quality pictures.
I don't know if that could matter, but I loaded the pictures with other settings and changed the product display after.
Hope I'm clear enough, but you can take a look at www.tri-mans.com/index.php/hikashop-menu-for-categories-listing and go inside one of the product listing / details and you'll see that the difference of picts size is quite noticeable...
I attached you a screen capture of the product listing display DIV parameters:
Thank's a lot for the help :)
-- url of the page with the problem -- : www.tri-mans.com/index.php/hikashop-menu...tegory/13-value-line
-- Joomla version -- : 3.1.5
-- PHP version -- : 5.3.1
Last edit: 12 years 10 months ago by Chameau. Reason: Mistake on the first shot...
  • Thank you received: 14189
12 years 10 months ago #129642
As far as I can see, you configured your products listing to display thumbnails in 100*100. Go in the menu Display->Content modules, edit your products listing module with the id 89 and set the width/height you want for the images and you'll see that they display like you want on the products listing.
For the product page, the settings are in the "Images" section of the Main tab of the configuration.
The following user(s) said Thank You: Chameau
12 years 10 months ago #129692
Perfect :cheer:
Time to create page: 0.328 seconds
