Product Description Alignment Problem
12 years 7 months ago #140544
For some reason products in a category that are not available to buy have a strange way of displaying the product description.
It is aligned to the right of the social icons instead of a new line.
See link below
www.miniaturemohairbears.co.uk/gallery/product/6-farquhar
Any ideas why this is, it displays fine on actual products for sale and have an add 2 cart button.
www.miniaturemohairbears.co.uk/minature-...s/product/33-clooney
Last edit: 12 years 7 months ago by Freakmode999.
12 years 7 months ago #140554
Did you done some modifications through the product view's files via "Hikashop->Display->Views" ?
Last edit: 12 years 7 months ago by Mohamed Thelji.
12 years 7 months ago #140561
No its stock, I just checked.
12 years 7 months ago #140602
Could you please tell me what tretemplate or file controls this view so I can reload it. I thought it was the same product layout just with add2cart disabled
I have just checked on a backup of this site sand it shows fine.
12 years 7 months ago #140606
OK fixed it - in the category the "Layout on Product Page" was set to reversed for some reason.
Changed to default and it now looks fine.
12 years 7 months ago #140665
Thanks for your feedback :).
