Related Products Module Before Description
  • Thank you received: 24
12 years 6 months ago #143728
I would like to display the module related products before the description of the product instead of under it.
I tried modifying the product-show view but was not able, is it possible?
12 years 6 months ago #143806
Can you show me through some screenshots what you exactly want to do, so that I can understand your issue and think about a solution :).
12 years 6 months ago #143813
I´ve already did it the solution was to copy the code from hikashop_submodules and insert it in views product tabular wich is the display i´ve choose.
then in css i hide the submodule under the product display.
12 years 6 months ago #143864
Thanks for your feedback :).
Last edit: 12 years 6 months ago by Mohamed Thelji.
