Module under products not displaying
  • Thank you received: 7
12 years 5 months ago #148761
Hi I have set the module under products to display in hikashop config and same in hikamarket. Now the same module is showing fine in hikamarket but not at all in hikashop. I think the module must be ok as it works in hikamarket. Please see attached the module selected in hikashop and the module config...
It should be showing on this page:
www.warestreetmarket.com/newsite/Browse-...tage-button-jar.html
It shows fine on this page:
www.warestreetmarket.com/newsite/Artist/vendor/show/cid-2.html
However for the second one as you know that is hikamarket.
Alex
  • Thank you received: 14186
12 years 5 months ago #148826
Your module is configured to display "related products" on the product page.
However, on your "vintage button jar" product, there are no related products:
www.warestreetmarket.com/newsite/adminis...roduct&task=edit&cid []=1
So it is normal that no products display below the product page with that module.
