Multilingual problems & product display
12 years 4 months ago #153544
-- url of the page with the problem (one of the many)-- :http://aedoszaden.nl/component/hikashop/product/255-koolraap-azur-star-biologisch-dynamisch
-- HikaShop version -- : essential most recent
-- Joomla version -- : 3. someting (completely upto date)
-- PHP version -- : 5.2 something something
-- Browser(s) name and version -- : Firefox most recent, explorer & chrome most recent
Okay so there is 2 problems,
I use a content module to display the products, however, if you cklick on the product this is still displayed above the product, can it not be that you can only see the product you clicked on? (before my upgrade to essential it worked like that perfectly fine but I forgot how to)
also, the Falang doubles everything from Hikashop, everything else is translated fine, but hikashop product and login pages and everything are shown double, how come? is there some settings in the translation I overlooked?
12 years 4 months ago #153549
Can you give us more information about that issues through some screenshots for example so that we can understand it ?
12 years 4 months ago #153642
Ok so I've added 3 screenshos, the overview document shows how a page looks when 1 product is clicked, in red are the other products in the category which are still displayed, I turned it off before (so that when you click on a product you only see that one) but I forgot how, that is question 1
then at the bottom of the page the product is dsplayed twice, one circled in yellow the other circled in green, the green one is the good one, the yellow one does not work. These issues arose when i installed Falang, is there some fields that i forgot to translate in order for this to work properly? problem 1 shows this issue as well but a bit zoomed in
normal 1 shows how the product overview looks and should look.
  • Thank you received: 14186
12 years 4 months ago #153663
I checked your page code and I can see that the main content of the page is displayed twice by the template. I don't know why your template is doing that (it's not a problem of HikaShop), but you can avoid that by adding such CSS on the website:
#sp-fp-clients-wrapper {
display: none;
I would however recommend to contact your template provider for help on that point.
Regarding the module being displayed on the product page, there are two things you need to do:
First, edit your module via the menu Display>Content modules and make sure that the "menu" option is configured to a products listing type menu item.
Second, edit your module via the joomla modules manager and make sure that this menu item is not selected in the "menu assignment" option of your module.
The following user(s) said Thank You: mike22
12 years 4 months ago #153727
Thanks, I managed to solve the issue with the product display,
I just have one question about the code, where can I put it (which file) the people from the template (joomlaman) are only replying that it has to do with my configuration and that I should install the quickstart package... so I guess I'll have to solve it myself so some help as to where to put it would be appreciated :P
12 years 3 months ago #153754
You can add it in the frontend CSS file of HikaShop and that should do it:
12 years 3 months ago #153803
and which view? it is displayed as menu now, but the problem is also with the login page etc, so just in all the views possibly related to it?
Last edit: 12 years 3 months ago by mike22.
12 years 3 months ago #153878
I said that you should add it in the CSS frontend file of HikaShop. As explained in the documentation, this can be done under the Display tab of the configuration. There is no view to select there.
If you see views, you're looking at the menu Display->Views which is something different.
12 years 3 months ago #153983
I see my mistake, and it works, thanks for the help it is enormously appreciated :-)
