Setting Joomla modules for products with menu item
12 years 3 months ago #157083
-- HikaShop version -- : 2.3.1 Essential
-- Joomla version -- : 3.3
how is it possible to set Joomla modules in pages that comes from a category/products listing ?
It seems that also if I create a menu item pointing directly to a product and set a joomla module for that menu item, if there is also a category list for that product, the product page will get the category modules instead of those modules set for the product menu item ?
I think this is also connected to a strange behaviour for breadcrumbs that I'm asking about in this post .
This is because if I substitute the correct menu item param (&Itemid=) everything works fine ... :dry: :huh:
Thank you for any suggestion !
Last edit: 12 years 3 months ago by gulp.
12 years 3 months ago #157306
To have different modules in a product page when coming from a listing, you will need the extension "advanced module manager".
In the options of the category module displayed on the product page, you can potentially select another "menu" option in order to have a menu displaying the desired modules.
12 years 3 months ago #157322
Thank you, I've never used this extension and I don't know how it will impact over the performance of the site (I'm trying to keep the number of the extensions installed very low...).
Do you think it is huge or light ?
12 years 2 months ago #157376
I think it is light. What I suggest is to see in how many time a page is loaded currently thanks to your browser console, then install the extension and see the variation of the page load time.
12 years 2 months ago #157512
Ok, I'll try this way !!
Thanx !!
12 years 2 months ago #158035
Hello again,
for a Content Display module how to make it works good ?
If the module is showing a list of products inside a category and I've to set a menu item inside the menu,
how to make a specific module to appear inside of the page of the specific product clicked by the content display module ?
Probably the best question is: how to make the Content Display module to make each product point correctly to his page and corresponding menu item ?
12 years 2 months ago #158088
Using the Advanced module manager will probably do the job.
To set the good menu item when you click on a product of your product listing content module, you'll just have to set the good menu through the "menu" option of your product listing content module.
12 years 2 months ago #158537
Like this it doesn't works:
- by using Advanced Module Manager I could set in which page/url a module will appear, but not to which pages each Content Display element will point to
- this settings is one-against-many, the module lists many items that should point to different pages, I suppose this should be strictly related to this post
Thank you
12 years 2 months ago #158800
I've made a fast update of the code to try to retrieve the menu item id.
I've updated two files in components/com_hikashop/views/product/tmpl/
(I think that once these becomes working these could be put as overrides in template joomla dir)
Add this code to listing_div.php
$db = JFactory::getDbo();
	$query = $db->getQuery(true);
	$query->select('*');
	$query->from($db->quoteName('#__menu'));
	$query->where($db->quoteName('link')." = ".$db->quote('index.php?option=com_hikashop&view=product&layout=show'));
	$db->setQuery($query);
	$result_menu = $db->loadAssocList();
	$prod_arr = array();
	foreach ($result_menu as $res_item)
		$prod_param = json_decode($res_item['params']);
		$prod_id = $prod_param->product_id;
		$prod_arr[$prod_id] = $res_item['id'];
	//print_r($prod_arr);
	$this->prod_arr = $prod_arr;
and updated the $link variable in listing_img_title.php like:
	$itemid = (int)$this->prod_arr[$this->row->product_id];
	$link = hikashop_completeLink('product&task=show&cid='.$this->row->product_id.'&name='.$this->row->alias."&Itemid=".$itemid);
What do you think about it ?
I know it's not really a good coding and not so good for performance, because it retrieves many menu items without filtering over the category on the query.
11 years 9 months ago #177146
is there a way to make this update stable, avoiding to be overwritten each time you release an official update ?
Last edit: 11 years 9 months ago by gulp.
11 years 9 months ago #177170
Yes, this could be useful !!
  • Thank you received: 14186
11 years 9 months ago #177203
Instead of editing directly the files in the folders, edit them for the "product" view for your template via the menu Display>Views of HikaShop and you won't loose the changes when you update HikaShop.
11 years 9 months ago #177333
Great, I didn't know this feature yet !
