link to products from category overview won't work
12 years 2 months ago #160055
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.3.1
-- PHP version -- :5.3.28
-- Browser(s) name and version -- : firefox 30.0
link: www.yohocards.nl/alle-series
The category page showing all the product categories does not work properly; the link per category to the related products won't work suddenly after the recent updates?! :unsure:
12 years 2 months ago #160064
If you are using a SEF module / SEF options, can you disable it and try it again ?
12 years 2 months ago #160370
Yes, after disabling sef the shop works again but Iam not very happy with that? Is there a work around fot this problem?
12 years 2 months ago #160396
1. What if you delete a menu and create a new one identical to the old one ?
2. Can you go to your Hikashop category listing configuration page and add one of your product listing content menu, through the "menu" option of your category associated module.
12 years 2 months ago #160734
I tried both options and switch sef on again, without any effect problem stays.
12 years 2 months ago #160740
also the pop-up window wjich appears after wanting to order an article won't show properly.
I tested the ht.accesmaker of admin tools - becuase it caused problems with another plugin in another website - perhaps that interferred but it didn't.
12 years 2 months ago #160753
Could you give us a screenshot of your HikaShop SEF settings ?
Do you have enabled the option to have smaller urls ? Disabled the one in order to not have product id in the url ?
If the second option is disabled, the product names must not start with a number.
12 years 2 months ago #160996
Hi, after altering settings only the categorie component still gives a non-sef url?
see the screendumps
  • Thank you received: 14186
12 years 2 months ago #161035
You need to turn back on the SEF options of the Joomla configuration like you had before, and turn off the "Remove products and categories id in URLs" option of the HikaShop configuration and that should fix the problem.
The following user(s) said Thank You: Joost
Time to create page: 0.397 seconds
