Category and subcategory display problem
12 years 2 months ago #160646
I'm using JSN Glass Pro with HikaShop. I had everything set and working, but I just noticed a template problem that was not there before. I haven't changed anything, so I'm not sure what happened.
The issue is with the pages that show my product categories and subcategories.
See siccreations.org/index.php/2014-03-31-18-29-07
and siccreations.org/index.php/2014-03-31-18...y/17-hair-clips-pins
Each Category used to be in a square container, showing 3 boxes per row. Now it is stretching the container all the way across the row with only 1 category per row.
How can I fix this?
  • Thank you received: 747
12 years 2 months ago #160720
In the HikaShop backend, go to Display -> Content menus and find the menu with ID 149 in the list. Open it and check what the "Number of columns" is set to. I bet it's "1". Set to "3", save, and all should be good.
12 years 2 months ago #160809
That sounded like it was it, but when I checked, It's already set to 3. Any other ideas?
12 years 2 months ago #160812
Solved! I added in a 3 in the number of columns box under Display -> Content menus-> Product categories under "Details" as it was blank. Thank you very much for your help lousyfool :cheer:
Time to create page: 0.184 seconds
