product category module doesn't work
12 years 1 month ago #163057
-- url of the page with the problem -- : candelori.renma.it/index.php?option=com_...t=listing&Itemid=112
-- HikaShop version -- : Version HikaShop [1405171505]
-- Joomla version -- : 3.3.1
-- PHP version -- : 5.3.28
-- Browser(s) name and version -- : firefox, safari, chrome, opera, explorer
hi,
the product category module doesn't work on my site.
In the written link there is the module on the right.
if I click on one of the categories don't appear the product in the category.
for example try to click to "farine per pizza" category.
in this category there are many products.
  • Thank you received: 14186
12 years 1 month ago #163102
This indicates that the target categories listing menu item of the module is not setup correctly.
Go in the menu Display->Content menus and edit it (id 118) on your website and check the settings there.
One or several options there are configured in a way that it doesn't display any product.
If you provide a screenshot of the options there, we should be able to tell you what's wrong.
Best regards,
Nicolas
12 years 1 month ago #163230
hi...here the screenshot.
thanks
12 years 1 month ago #163231
If you want your products to be displayed, you'll have to make sure that the category listing content menu that you have set through the "menu" option of your content module HAVE an associated content module through the "Associated modules" option which will displayed your categories products.
12 years 1 month ago #163405
thanks i've solved!!!!
There is a module that show the product!!!!
The product not displayed like an article. I've published a module that show the precut for each category.
Time to create page: 0.205 seconds
