Products are displayed without order
12 years 1 month ago #163439
-- url of the page with the problem -- : escolatur.com/clon
-- HikaShop version -- : bussiness
-- Joomla version -- : 31
-- PHP version -- : x.x.x
Hi:
First at all, thanks for your earlier responses!
When I display products for a category it runs perfectly, but the breadcrumbs has "Menu item for category listing module 211" (I renamed it as "Listado de cursos") and when I press on this item of the breadcrumb, the products are listed without any order.
I would like order them on categories or alphabetically.
How can I do this?
Thanks in advance!
Leonora.
  • Thank you received: 14186
12 years 1 month ago #163443
Go in the menu Display>Content menus, edit the menu called "Listado de cursos" and there you can configure the ordering column and ordering direction of the products listing.
Note that you'll find the options twice on the page, once for the categories listing and once of the products listing so you want to configure the second ones, for the products listing.
12 years 1 month ago #163565
Thanks! It runs!
