I need to display unique ID within product.
12 years 1 month ago #164890
-- url of the page with the problem -- :n/a
-- HikaShop version --HikaShop Starter 2.3.2
-- Joomla version -- :3.3.1
-- PHP version -- : x.x.x
I would like to have Item # as in example below:
www.overstock.com/Clothing-Shoes/Bonnibe...C4LQB6CI&searchidx=1
Is there a way to display unique numeric ID for the product?
Or change Code to be unique numeric number?
12 years 1 month ago #164924
The solution will probably just be to create a "product" custom field through "Hikashop->Display->Custom fields" and set an ID through your product configuration pages, then that custom field value will show through your product page.
12 years 1 month ago #165073
Thank you for your response! Do you think it is possible to get a piece of code in to make this Unique ID to be generated?
Product Code can be used as well, but it is a manual entry every time. I am looking for something that generates unique ID(like a primary key in DB table) that can be displayed withing a product. :unsure:
12 years 1 month ago #165074
..or may be an option is to display Product ID (which i understand is unique key(PK)) on the product page.....
Reason is, a lot of folks order over the phone/email in my case. And with extensive inventory it is very hard to figure out which exact product customer wants to order. With Item # (Product ID, Code etc) it is waaaay easier to accomplish so. And it is waaay easier to do that when ID is generated by the system without "laborious" manual entry :)
thank you in advance
12 years 1 month ago #165080
In your case, using the HikaSerial will probably help you : www.hikashop.com/extensions/hikaserial/product.html#features
But note that if you want to daily update your products custom field value, a solution can be to use mass actions through "Hikashop->System->Mass actions".
The following user(s) said Thank You: atmosfera
12 years 1 month ago #165168
Yes, that might work well. Thank you!
