Need a field to order my products
12 years 1 month ago #165231
on www.oneart.ro I have a lot of products (about 150.000) and I can't order them by hand.
I saw on the configuration page that I can order based on about any field of the product.
I need a field that won't affect any other part of the product. I was wondering if I can use product_delay_id field.
I searched the forums and even Google and couldn't find any mention of this field or what it does.
Bottom line, I need to be able to import a CSV with the product_id and another product_ field where I can input a value from 10.000 to 1, so I can set my ordering based on that field.
Please help me with a field I can use.
Thank you!
12 years 1 month ago #165244
A solution will be to create a product custom field through "Hikashop->Display->Custom fields", set it through your CSV file, and then order your product regarding that custom field.
The following user(s) said Thank You: lex131
12 years 4 weeks ago #165757
Thank you for your response.
Can you tell me how to order them?
I mean, if:
Product A: ID 10001
Product B: ID 10002
Which one will be shown first?
I want to know what values should I put in that new field.
Thank you!
12 years 3 weeks ago #165762
Once the custom field created, you can put numbers for example to order your products.
And it will be ordered from the smaller to the greater one.
12 years 3 weeks ago #165888
Thank you!
