HikaShop problem with translation
12 years 4 weeks ago #165816
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.5.9
After login i don't see anymore flags from falang to do translations: prntscr.com/47lqpq , falang database driver is active, for other translations i use joomla multilang. system... what can be the problem here?
12 years 4 weeks ago #165821
What is your HikaShop configuration for the multi language ?
www.hikashop.com/support/support/documen...onfig.html#languages
What is your falang version ?
12 years 3 weeks ago #165878
This setup was in my configuration disabled, but after installation it was active... Falang version is 1.4.0
12 years 3 weeks ago #165898
If you have no more the flags, so it is because FaLang is no more installed/enabled.
Or the option to activate the edition of content in multiple languages is disabled.
Or you have only one language published.
If all the previous points are correct, thanks to give us a backend access via private message with a link to that topic.
