Same product description for all products!
12 years 3 weeks ago #166290
Hi All,
i would like to create the same product description for all products (i'm selling just one kind of product but with more options)
How can i do this?
Obviously, for each language.
Thanks in advance
Andrea
  • Thank you received: 14186
12 years 3 weeks ago #166296
The simplest is to edit the file "show" of the view "product" via the menu Display>Views and add at the beginning something like that:
<?php
$lang = JFactory::getLanguage();
switch($lang ->getTag()){
 default:
 case 'en-GB':
  $this->element->product_description = 'My description in english';
  break;
 case 'fr-FR':
  $this->element->product_description = 'Ma description en francais';
  break;
Last edit: 12 years 2 weeks ago by Jerome. Reason: code fix
12 years 3 weeks ago #166334
Thanks Nicolas,
but, in 'My description in english? can i put a HTML code?
Because, description has a table and image inside.
Andrea
12 years 3 weeks ago #166352
Yes, you can.
And you can also use Joomla tags.
12 years 3 weeks ago #166487
Hi All,
i've tried to put at the beginning the code, but it dosn't work.
<?php
switch($language->getTag()){
 default:
 case 'en-GB':
  $this->element->product_description = 'English Test';
  break;
 case 'it-IT':
  $this->element->product_description = 'Prova Italiano';
  break;
<?php
 * @version	2.3.1
 * @author	hikashop.com
 * @copyright	(C) 2010-2014 HIKARI SOFTWARE. All rights reserved.
?><div id="hikashop_product_top_part" class="hikashop_product_top_part">
<?php if(!empty($this->element->extraData->topBegin)) { echo implode("\r\n",$this->element->extraData->topBegin); } ?>
	<h1>
		<span id="hikashop_product_name_main" class="hikashop_product_name_main">
			<?php
			if (hikashop_getCID('product_id')!=$this->element->product_id && isset ($this->element->main->product_name))
				echo $this->element->main->product_name;
			else
				echo $this->element->product_name;
		</span>
		<?php if ($this->config->get('show_code')) { ?>
		<span id="hikashop_product_code_main" class="hikashop_product_code_main">
			<?php
			echo $this->element->product_code;
		</span>
		<?php } ?>
	</h1>
<?php if(!empty($this->element->extraData->topEnd)) { echo implode("\r\n",$this->element->extraData->topEnd); } ?>
<?php
	$pluginsClass = hikashop_get('class.plugins');
	$plugin = $pluginsClass->getByName('content', 'hikashopsocial');
	if(!empty($plugin) && (@$plugin->published || @ $plugin->enabled)) {
		echo '{hikashop_social}';
</div>
<?php if(HIKASHOP_RESPONSIVE){ ?>
	<div class="row-fluid">
<?php } ?>
<div id="hikashop_product_left_part" class="hikashop_product_left_part span6">
	<?php
	if(!empty($this->element->extraData->leftBegin)) { echo implode("\r\n",$this->element->extraData->leftBegin); }
	$this->row = & $this->element;
	$this->setLayout('show_block_img');
	echo $this->loadTemplate();
	if(!empty($this->element->extraData->leftEnd)) { echo implode("\r\n",$this->element->extraData->leftEnd); }
</div>
<div id="hikashop_product_right_part" class="hikashop_product_right_part span6">
	<?php
	if(!empty($this->element->extraData->rightBegin))
		echo implode("\r\n",$this->element->extraData->rightBegin);
	<div id="hikashop_product_vote_mini" class="hikashop_product_vote_mini">
		<?php
		$config =& hikashop_config();
		if($this->params->get('show_vote_product') == '-1'){
			$this->params->set('show_vote_product',$config->get('show_vote_product'));
		if($this->params->get('show_vote_product')){
			$js = '';
			$this->params->set('vote_type','product');
			if(isset($this->element->main)){
				$product_id = $this->element->main->product_id;
			}else{
				$product_id = $this->element->product_id;
			$this->params->set('vote_ref_id',$product_id);
			echo hikashop_getLayout('vote', 'mini', $this->params, $js);
	</div>
	<span id="hikashop_product_price_main" class="hikashop_product_price_main">
		<?php
		if ($this->params->get('show_price')) {
	</span>
	<?php
	if(!empty($this->element->extraData->rightMiddle))
		echo implode("\r\n",$this->element->extraData->rightMiddle);
	<?php
		$this->setLayout('show_block_dimensions');
	?><br />
	<?php
	if($this->params->get('characteristic_display')!='list'){
		$this->setLayout('show_block_characteristic');
		<br />
	<?php
	$form = ',0';
	if (!$this->config->get('ajax_add_to_cart', 1)) {
		$form = ',\'hikashop_product_form\'';
	if (hikashop_level(1) && !empty ($this->element->options)) {
		<div id="hikashop_product_options" class="hikashop_product_options">
			<?php
			$this->setLayout('option');
		</div>
		<br />
		<?php
		if ($this->config->get('redirect_url_after_add_cart', 'stay_if_cart') == 'ask_user') {
			<input type="hidden" name="popup" value="1"/>
		<?php
	if (!$this->params->get('catalogue') && ($this->config->get('display_add_to_cart_for_free_products') || !empty ($this->element->prices))) {
		if (!empty ($this->itemFields)) {
			<?php
			$this->setLayout('show_block_custom_item');
	$this->formName = $form;
	if($this->params->get('show_price')){ ?>
		<span id="hikashop_product_price_with_options_main" class="hikashop_product_price_with_options_main">
		</span>
	<?php }
	if(empty ($this->element->characteristics) || $this->params->get('characteristic_display')!='list'){ ?>
		<div id="hikashop_product_quantity_main" class="hikashop_product_quantity_main">
			<?php
			$this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form\')){ return hikashopModifyQuantity(\'' . $this->row->product_id . '\',field,1' . $form . ',\'cart\'); } else { return false; }';
			$this->setLayout('quantity');
		</div>
	<?php } ?>
	<div id="hikashop_product_contact_main" class="hikashop_product_contact_main">
		<?php
		$contact = $this->config->get('product_contact',0);
		if (hikashop_level(1) && ($contact == 2 || ($contact == 1 && !empty ($this->element->product_contact)))) {
			$empty = '';
			$params = new HikaParameter($empty);
			global $Itemid;
			$url_itemid='';
			if(!empty($Itemid)){
				$url_itemid='&Itemid='.$Itemid;
			echo $this->cart->displayButton(JText :: _('CONTACT_US_FOR_INFO'), 'contact_us', $params, hikashop_completeLink('product&task=contact&cid=' . $this->element->product_id.$url_itemid), 'window.location=\'' . hikashop_completeLink('product&task=contact&cid=' . $this->element->product_id.$url_itemid) . '\';return false;');
	</div>
	<?php
	if(!empty($this->fields)){
		$this->setLayout('show_block_custom_main');
	<span id="hikashop_product_id_main" class="hikashop_product_id_main">
		<input type="hidden" name="product_id" value="<?php echo $this->element->product_id; ?>" />
	</span>
	<?php
	if(!empty($this->element->extraData->rightEnd))
		echo implode("\r\n",$this->element->extraData->rightEnd);
</div>
	</div>
<?php } ?>
<div id="hikashop_product_bottom_part" class="hikashop_product_bottom_part">
	<?php
	if(!empty($this->element->extraData->bottomBegin))
		echo implode("\r\n",$this->element->extraData->bottomBegin);
	<div id="hikashop_product_description_main" class="hikashop_product_description_main">
		<?php
		echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description));
	</div>
	<span id="hikashop_product_url_main" class="hikashop_product_url_main">
		<?php
		if (!empty ($this->element->product_url)) {
			echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>');
	</span>
	<?php
	$this->setLayout('show_block_product_files');
	<?php
	if(!empty($this->element->extraData->bottomMiddle))
		echo implode("\r\n",$this->element->extraData->bottomMiddle);
	<?php
	if(!empty($this->element->extraData->bottomEnd))
		echo implode("\r\n",$this->element->extraData->bottomEnd);
</div>
Where is the issue?
Andrea
12 years 2 weeks ago #166492
If you don't see any change, then it means that you're not editing the view file for the current template on your frontend. Please make sure that you're editing the view for the template you're using when you're in the menu Display>Views.
12 years 2 weeks ago #166556
Yes, i'm sure. The template is correct and also the file.
Nothing happened.
Can you help me?
Andrea
12 years 2 weeks ago #166574
Please provide a backend access via our contact form so that we can check your settings and the change:
www.hikashop.com/contact-us.html
Please provide a link to this thread in your message
12 years 2 weeks ago #166650
i did it.
Andrea
12 years 2 weeks ago #166897
I checked the code and there was a PHP misspelling in the code that Nicolas provided you which made an error.
I fixed the code in the Nicolas post and I put it in your "show" view in order to provide you a working sample.
I saw that you're using some variants. Please note that if you put a description in the variant, it won't be override by the code we provided you (it will require other kind of code to override the variants' descriptions)
12 years 2 weeks ago #166918
Hi Jerome,
thanks for reply and your help. Don't worry about variants because i'd like to write the options in main description.
Many thanks!!
Andrea
Last edit: 12 years 2 weeks ago by andreasuriani. Reason: solved
12 years 2 weeks ago #167131
Hi All,
is it possible include in this code another code? I mean, the code works perfectly, but i'd like to create 2 kinds of description 1of all products (called global) and 1 of single product.:
Example:
Product 1
Description (Input on product insert) : Bla Bla Bla (Ita) and bu bu bu (Eng)
Show product on FrontEnd:
Product 1 (ITA)
Bla Bla Bla
Description global
Is it possible?
Andrea
12 years 2 weeks ago #167134
I don't understand your message or what your want to achieve exactly but : Yes, it's possible.
You can use a product custom field in order to know if it's "global" or not "global".
It will require some PHP/development skills.
12 years 2 weeks ago #167192
Can you help me with the code ?
12 years 1 week ago #167195
We already are far from standard user support here.
If you need someone to do custom development for you, I would recommend that you request a quote to our partners ( www.hikashop.com/home/our-partners.html ) and/or via our commercial jobs forum so that a third party developer can do that for you.
