Create a Door Configurator with custom fields
  • Thank you received: 24
12 years 3 weeks ago #166470
-- Joomla version -- : 3.3.3
I have to create a configurator in wich people can choose the door type they want. But in the options or characteristics wich will increase the price i would like to have images, so they can choose the wood type, and the color of the door etc...
Is it possible?
  • Thank you received: 14186
12 years 2 weeks ago #166484
With characteristics, you can set the "characteristics display method" to "radio" in the confguration and directly enter the HTML of the img HTML tag of your images as values of the characteristic so that the user will be able to select the characteristic on the product page using the image of the values of the characteristic.
