Related Products displays ALL products in category
11 years 11 months ago #170799
-- Joomla version -- : 2.5.24
-- PHP version -- : 5.3.24
-- Browser(s) name and version -- : all browsers
Related Products and Recently Viewed just displays ALL products in a category.
I have trawled the forums but found nothing that seems to help.
Attached is the config and results from a particular page; But this consistently happens on all product pages.
In the attached example the first product
shows 3 related products all from the 'Conveyors' section but the product page shows all the products from the current category 'Mixers'
Also the recently viewed is doing exactly the same.
This is driving me crazy. Hope its something you can quickly help with.
Kinds Regards
Tim
11 years 11 months ago #170805
In the settings of your modules I can see that there is an assigned category, the "sales" category, is the "Conveyors" category in the "Sales" one ? If not, thanks to change the associated category.
11 years 11 months ago #170908
Hi Xavier,
Thanks or you quick response.
I have changed the Associated Category for "Conveyors" to "Sales" - no difference.
In addition I also changed the Associated Category for the parent category (Machinery) - no difference.
Tim
11 years 11 months ago #170914
Can you give us a link to one of your product/category listing where you are having your issue, and also show us how did you configured your product/category listing content menu through some screenshots ?
11 years 11 months ago #171126
Morning Mohamed, would it be better for you to login and see the configuration? I can PM the details.
11 years 11 months ago #171198
1. Regarding your "Mixers" product listing content menu for example, the solution will probably be to set the "category" option to Sales/Machinery/Mixers instead of Sales, so you won't have unwanted products displayed.
2. Regarding your "Related products" module as it's said on the following tutorial, you'll have to publish your "related products" module through the "Modules to display under the main area" option of the page "Hikashop->System->Configuration->Display" : www.hikashop.com/support/documentation/i...ct-form.html#related
11 years 11 months ago #171310
Now that's looking much better,
Tim
Time to create page: 0.534 seconds
