Related products module not showing up
11 years 11 months ago #172263
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.3.28
-- Browser(s) name and version -- : Mozilla Firefox 31.0
Hi guys,
I have a problem with related products module not showing up on the product page, for any of the products.
I followed Hikashop documentation on how to set this up but it just doesn't work.
I also attached screenshots of hikashop config page , and hikashop module config page.
Please help!
Thanks,
Dushan
11 years 11 months ago #172266
As every Joomla modules, you have to assign it to the Joomla menus.
To have it on the product page, the module must be assigned to the menu used to reach that product page.
If you want the module only on product pages but not on listings, then you will need "advanced module manager".
11 years 10 months ago #172550
Xavier,
Module is assigned to all Joomla menus but still doesn't work.
Also, what do you mean when you say "advanced module manager''?
Thanks,
Dushan
11 years 10 months ago #172552
If you change the kind of "content on product", does the module show up (like "in the same categories") ?
Does your problem right have related product in his configuration ?
In which position is your module ?
11 years 10 months ago #172681
Jerome,
I'm sorry, but I don't understand what do you mean. Can you,please, re-phrase questions 1 and 2?
I didn't assign any position to the module.
Thanks,
Dushan
11 years 10 months ago #175683
Hello Dushan,
Sorry for the late reply, to be sure, did you correctly followed each step of the documentation to make your related product display through your product page ?
How to display your related products below your products:
1. Create a new module of the type "HikaShop content module" via the joomla modules manager and leave it unpublished in the joomla options of the module.
2. In the HikaShop options of the module (there is a link to them on the right of the module's joomla options screen), make sure that the "Type of content" option is set to "product" and that the option "Content on product page" is set to "Related products".
3. In the configuration of HikaShop, click on the "Select" button of the "Modules under the product page" option. Set your related module to published and click on OK. Then, save the configuration.
  • Thank you received: 7
10 years 1 month ago #245916
does related product module need motools library for work ?
Mohamed Thelji wrote: Hello Dushan,
  • Thank you received: 14184
10 years 1 month ago #245921
No, it doesn't. It will display the related products regardless.
9 years 11 months ago #250227
I am having the same problem. Did anyone find a solution?
When inspecting the source, there is a line that says:
<div class="item item1" style="visibility: hidden;">
I'm sure that is not supposed to be hidden. What is causing that?
Also, when I do comment out that "hidden" in the inspector, the link for the product takes me to a bad link:
index.php/component/hikashop/product/209-ultimate-tote?Itemid=511
it should be:
index.php/bags/product/209-ultimate-tote
9 years 11 months ago #250270
Hello
Can you provide a screenshot of Related Product module and especially this red bordered part ?
=> HikaShop Options tab
=> Menu Assignment tab
A link will be usefull too.
Awaiting news from you.
Regards.
Last edit: 9 years 11 months ago by Philip.
9 years 11 months ago #250323
I believe I have all of the settings correct. But feel free to look.
webarchitechsnc.com/mis2/index.php/bags/...ct/209-ultimate-tote
9 years 11 months ago #250381
Everything seems well configured, can you try to switch your template for Protostar, and see if you can see your Related module ?
If that solve your issue contact your template provider support.
9 years 10 months ago #250566
It does seem like a template problem. I switched it to protostar as suggested and they show up fine.
I guess I'll reach out to them.
Time to create page: 0.412 seconds
