remove per unit for buying at least from module
11 years 10 months ago #173602
-- Joomla version -- : 3.3.4
-- Error-message(debug-mod must be tuned on) -- : Hello
I would like all of the modules delete the entry of the order quantity . I do this through css , but it is a bit pointless , since the creation of each module in the CSS I need to add this code:
# hikashop_category_information_module_114 div.hikashop_product_price_per_unit_x
{display : none; }
I do not want to repeat in the near module_114 , module_115 , etc. module_115 so please podpowieć like forever to delete this post ?
If I remove it in a file listing_price , this text disappears in the details of a specific product .
Please help me how to remove the modules.
Peter
ps . sorry for my english but I'm using google translate
Hello
{display : none; }
Peter
11 years 10 months ago #173603
A solution can be to use a better CSS code which won't need the id of you module like :
.hikashop_module .hikashop_products_listing_main .hikashop_products_listing .hikashop_product_price_per_unit {
display: none;
11 years 10 months ago #173690
pasted the code that you gave me and unfortunately does not work
11 years 10 months ago #173693
And this code:
.hikashop_module .hikashop_product_price_per_unit_x {
display: none !important;
The idea is to use a more global css rule, so you can use your browser console to find the best classes to apply the css on. :)
The following user(s) said Thank You: piotreczek100
11 years 10 months ago #173805
thank you very much :) now it's ok. I have another question;)
How to do that in the modules before the price was the text "from" added the entry in listin.price.php but then this post shows up everywhere and I would like to have it just in modules.
Yours sincerely
11 years 10 months ago #173914
To restrict the display of something to the modules only, you can use code like:
if($this->params->get('from_module',0) != 0){
  // Display the content
11 years 10 months ago #174108
Hello, and where should I paste this code?
11 years 10 months ago #174115
I don't know which kind of data you are displaying in your module ; but you should edit the corresponding view.
I think that your documentation on display customization will help you:
