Custom Fields for products
11 years 10 months ago #174527
-- HikaShop version -- : HikaShop Essential 2.3.3
-- Joomla version -- : 3.3.3.
-- PHP version -- : 5.4.30
-- Browser(s) name and version -- : Firefox 32
Hello Support team,
im trying to set up a field for diameter. I wannt it to appear in the products like lenght and highth and so on.
I have published the new, but i cant see the new field anywhere.
Thx
Andreas
11 years 10 months ago #174542
To do that a solution can be to create 2 Item custom fields which are only available through the business version.
11 years 10 months ago #174649
Thx
and how do i do that?
which table do i have to use?
Thx
Andreas
11 years 10 months ago #174664
You'll have to create them via "Hikashop->Display->Custom fields" and set their "Table" option to Item.
11 years 10 months ago #174799
awesomescreenshot.com/05a3mdmvf9
awesomescreenshot.com/0ee3mdne2f
Hello it does not seem to work.
What am i doing wrong?
  • Thank you received: 14186
11 years 10 months ago #174888
It seems mohamed didn't understand your question. If you want a field to work like the "weight", "width", etc fields, you want to create a custom field of the table "product" and not of the table "item". The custom fields of the table "product" will display on the product edition page on the backend while the custom fields of the table "item" will display on the product details page on the frontend.
11 years 10 months ago #174940
I tried this nicolas
but it does not work.
Anyidea why?
11 years 10 months ago #175025
Can you please provide a screenshot of the options screen of your custom product field so that we can see how you configured it ?
11 years 10 months ago #175669
11 years 10 months ago #175686
The only thing which could cause this problem is the restriction on the category.
Is that your main product category, or at least the parent category of the products which must have a diameter ?
11 years 10 months ago #176008
Deko is the parent category
i activated subcategories too but with no success
11 years 10 months ago #176074
What is "no success" ?
The configuration of your product custom field looks good (except for the category part where we can't know if it is really good or not).
But, if the category is right, you should be able to see the custom field in the HikaShop backend and then, in the front-end for the products which have the custom field and which have a value for the custom field.
11 years 10 months ago #176135
awesomescreenshot.com/07e3opsj31
awesomescreenshot.com/0f73opsmc2
see ?
it does not work this way
where is the failure?
11 years 10 months ago #176137
Okay
i have to choose every subcategory :-(
But i want the field to show up like length heigth and so on
awesomescreenshot.com/09c3optr1e
How do i do that ?
11 years 10 months ago #176163
Edit the file show_block_custom_main via the menu Display>Views, cut all the code from it and paste it in the show_block_dimensions file and you'll get the custom field right below the dimensions area.
And you remove the specification text, you can use some simple CSS to hide it:
.hikashop_product_custom_info_main h4{ display: none; }
11 years 10 months ago #176501
Sorry nicolas
this does not work for me
i get a blank screen
11 years 10 months ago #176626
If you got a blank screen it means that you have a PHP fatal error.
Please check your PHP error log or activate the error reporting in your Joomla global configuration.
11 years 9 months ago #177008
Cant find a fix.
would it be possible for you to have a lokk at it.
thx
11 years 9 months ago #177022
Did you check your PHP error log ? Also can you activate the error reporting in your Joomla global configuration so that we can have more information about the error that you are having ?
11 years 9 months ago #177491
Yes i did but no clue what to do.
I want to have costum fields displayed under the normal fields like lenght height..... and so on
thx
Time to create page: 0.104 seconds
