Custom Fields for products
11 years 9 months ago #177511
Nicolas already gave you the solution/process for that :
Edit the file show_block_custom_main via the menu Display>Views, cut all the code from it and paste it in the show_block_dimensions file and you'll get the custom field right below the dimensions area.
And you remove the specification text, you can use some simple CSS to hide it:
.hikashop_product_custom_info_main h4{ display: none; }
11 years 9 months ago #177671
it did not work
11 years 9 months ago #177675
I am sorry but the Nicolas' solution is working.
this does not work for me
i get a blank screen
If you are not able to implement it ; the best will be to see with an external developer or one of our partners.
11 years 9 months ago #177752
where can i find those partners
11 years 9 months ago #177762
Well, in the partner page
www.hikashop.com/home/our-partners.html ( accessible though the "home" menu ).
