Product options are not displayed in the right way
11 years 9 months ago #180300
-- url of the page with the problem -- : blueorchid.ie/category-listing-module/pr.../1014-red-curry.html
-- Joomla version -- : 3.2.7
-- PHP version -- : 5.3.28
-- Browser(s) name and version -- : Chrome 38.0.2125.122
After I updated hikashop to the latest version, the options of the product are now displayed beside the photo instead of below it. How can I fix it?
11 years 9 months ago #180341
The solution will just be to edit the "Show_default" file of the "Product" view of your front-end template and move the "hikashop_product_options" DIV under the "hikashop_product_top_part" or "hikashop_product_bottom_part" DIV via "Hikashop->Display->Views".
11 years 9 months ago #180485
I did what you said but nothing changed. I have a few templates in the list. I chose the one which is also the template of Joomla. How can I know which template is right and in effect?
Anyway, I tried to change Show_default for every template available, but none of them had any effect.
  • Thank you received: 14186
11 years 9 months ago #180489
Add the line:
<?php exit; ?>
at the beginning of the file and if it's the correct one, you'll get a blank page on the product page (so you'll be sure that you're looking at the correct view file for the correct template).
If you tried for all the show_default files, then it's probably that you're not using the default layout of the product page but another one like show_tabular or show_reverse. Try to edit these for your frontend template.
