Problem with add to cart popup on mobile/tablet
11 years 8 months ago #183319
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.3.27
-- Browser(s) name and version -- : Chrome newest
When i add items to cart in desktop it will display like
but if its on tablet it will show like
how to change it back to look like desktop?
looks like the popup system are changed recently because in the older hikashop version the mobile/tablet popup is same as desktop
Last edit: 11 years 8 months ago by veeco.
11 years 8 months ago #183348
There is maybe some css properties in your template which are overriding ours and set the popup size bigger.
Please read that tutorial and add @media queries on small resolutions for this popup. The css properties will require to be present in your template css file as the hikashop css file is not loaded in popups.
11 years 8 months ago #183453
i tried installing hikashop into fresh new joomla
it looks like its from hikashop itself by default
any suggestion?
11 years 8 months ago #183678
I just done a fresh install on Joomla 3.3.6 and HikaShop 2.3.4 and I don't have this issue.
So please try to use HikaShop 2.3.4 and update Joomla.
11 years 8 months ago #184084
Hello I tried it again with newest joomla and newest hikashop
Problems still there
what i want it looks like
Newest Version
11 years 8 months ago #184116
Without any direct access to your website it will be hard to know from which CSS property your issue is coming, also note that I just tested it on a fresh install and it worked fine.
11 years 8 months ago #184207
Mohamed Thelji wrote: Hello,
Hi, i've uploaded it to server
dxc-server.com/vanilla
how to send you the access info?
11 years 8 months ago #184217
You can send the access info via private message or via our contact form.
In both cases, please don't forget to five us the url of that topic.
Please try to edit the values for the option "Add to cart popup size" in Configuration > Main > Cart.
