Product bundle / 2 and more Products with one clic
11 years 8 months ago #184282
-- Joomla version -- : 3.3.6
Hello everybody and merry xmas!
I am facing a problem ... i am using the "add to cart" html link.
Now i want and have to to the following thing.
When i click the button, it has to add 2 products at the same time.
Is it possible to do something like that?
Can i type "http:/...option=com_hikashop&ctrl=product&task=updatecart&quantity=1&checkout=1&product_id=2-AND-ONE-MORE"?
Thank u very much!
11 years 8 months ago #184308
a friend of mine made a great workaround with JS.
If there is any solution in hika, it woould be nice to know. if there is not .... no problem :)
Thanks and merry xmas!
  • Thank you received: 14186
11 years 8 months ago #184296
Here is a URL for that:
www.hikashop.com/forum/4-how-to/9701-upd...f-quantity.html#9724
XX is the id of the first product
0 the quantity of the first product to add
YY is the id of the second product
1 the quantity of the second product to add
The following user(s) said Thank You: pixeldraft
11 years 8 months ago #184386
Thank u very much!
Now i am facing one more problem with the add to cart link.
If i want to add the same product to the cart again, the qty is still 1.
11 years 8 months ago #184403
Add the attribute &add=1 to the URL and the quantity of the products in the URL will be added to the ones in the cart instead of replacing them.
