Problem with category grouping on product listing
11 years 8 months ago #184402
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.4
-- Browser(s) name and version -- : IE
I have a problem with the product listing page. I need to display the products that are grouped by category
To explain a bit I have the following categories and sub-categories
Face
- Face Pack
- Face Wash
Body
- Soap
- Lotion
Each of the sub-categories have multiple products. On the product listing page following is displayed
Face Pack
All products of Face pack
Soap
All products of Soap
Face Wash
All products of Face wash
Lotion
All products of Lotion
However I need the display as the categories have been defined as
Face Pack
Face Wash
Soap
Lotion
Can you please explain how this grouping can be achieved?
~Sanket
  • Thank you received: 14186
11 years 7 months ago #184412
It's simple. Edit your product listing menu via the menu Display>Content menus of HikaShop and set the "sub element filter" option to "group by category" and it will display like that.
11 years 7 months ago #184435
The ordering of groups is not correct with this option enabled.
I want o show it as
1.1
1.2
2.1
2.2
However with this option enabled, it shows
1.1
2.1
1.2
2.2
Please advice
11 years 7 months ago #184458
You can have a look at the beta site
www.sscpl-india.com/sscpl_main/index.php/products
I expect the categories as
Face Wash
Face Pack
Cream
However it shows
Face Wash
Luxury Soap
Shampoo & Conditioners
How can I achieve the categories as they have been shown in the right categories module
~Sanket
11 years 7 months ago #184485
First, make sure that the categories are ordered properly (order column of the categories listing).
Second, try to click on the "rebuild" button of the categories listing.
If that doesn't help, it might be something that we fixed since your version so try to update HikaShop.
And if that doesn't help, we would need to have a closer look at how your products and categories are configured in order to understand why it doesn't work.
11 years 7 months ago #184518
I have tried all the 3 things suggested. I have also updated to HikaShop version 2.3.5. But the problem is still not solved.
Please suggest.
~Sanket
11 years 7 months ago #184580
Please provide a backend access via our contact form with a link to this thread so that we can check your settings
11 years 7 months ago #184584
You can access the URL www.sscpl-india.com/sscpl_main/administrator
Sanket
11 years 7 months ago #184702
Thank you for the access.
Please replace the file components/com_hikashop/views/product/view.html.php with the one in the archive below and it should fix the issue.
The following user(s) said Thank You: sanket.pattekar
11 years 7 months ago #184765
Superb !!!! Thankyou.....
Sanket
