Product Images Not Resizing for Phone and Tabs
  • Thank you received: 6
11 years 6 months ago #190110
I am using Joomla 3.3.6 with current Hikashop Business updated. My issue is that when my site is being viewed on smaller items like phones and tablets, my images do not resize and get all bunched up.
What is the solution to get the images to resize for these smaller devices?
Thank you,
Charles
11 years 6 months ago #190127
The best will be to use a responsive template (compatible with bootstrap 2) in order to use the HikaShop bootstrap design.
So it will provide some special CSS rules to change the size of the images so they will feet correctly in the phone/tab screen.
11 years 6 months ago #190142
I am currently using Template Creator CK which is setup for Mobile responsive.
11 years 6 months ago #190171
You should have this property in the frontend_default.css file from the menu Configuration > Display > CSS:
.thumbnail div.hikashop_product_image_subdiv {
	width:100% !important;
This allow to have an image in percent, so the image should be resized unless there is another property overriding this one or if you are not using this css file.
Please do some checks thanks to your browser console, here is some documentation for that.
11 years 6 months ago #190227
Yep I have it set just like that but just not resizing. The rest of my template is responsive to the phone size, just the shop is not.
Also the Carousel slide never shrinks or reduces to single column for phone. It instead stays wide and full sized while everything else changes.
Last edit: 11 years 6 months ago by fan4chevy.
11 years 6 months ago #190249
If your template is responsive and compatible with Bootstrap 2, you can use the bootstrap design in HikaShop.
11 years 6 months ago #190283
do i just click bootstrap?
  • Thank you received: 747
11 years 6 months ago #190297
HikaShop backend -> System -> Configuration -> tab Display -> General display options -> set option "Use bootstrap design" to "Yes".
Unless something has changed during the most recent past, the HikaShop Carousel is not responsive. It would take some "tricks" or another extension to get a (quasi) responsive carousel effect.
Last edit: 11 years 6 months ago by lousyfool.
