Where to set column numbers for Related Products
11 years 6 months ago #191201
-- url of the page with the problem -- : apf.cloudaccess.net/dvd/product/scripture-mysteries-bundle
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.29
-- Error-message(debug-mod must be tuned on) -- : no error message
I am pretty sure I set up the Related products to all be three columns but I want to set them to two since I believe I will like that better. It is probably really easy but I keep missing it. Where are those settings?
Thank you, Sean
11 years 6 months ago #191234
I also want to make RECENTLY VIEWED two columns
  • Thank you received: 747
11 years 6 months ago #191273
You are referring to regular "HikaShop Content Modules", which you can create or find and edit either through HikaShop's menu -> Display -> Content modules, or via Joomla's Module Manager.
The following user(s) said Thank You: scarney
11 years 6 months ago #191522
Here is an example page: apf.cloudaccess.net/dvd/product/transfor...med-life-10-messages
I keep trying to find these settings. It must be somewhere. I have been looking for hours. What I want is to change the columns of the Related Products to two instead of three.
Last edit: 11 years 6 months ago by scarney.
11 years 6 months ago #191523
OK. I found it. That was a bit tricky. I had to go to the modules and then click the check box next to the module I wanted to edit and click on the edit button.
11 years 6 months ago #191547
You can also simply click the module name.
