Need a little help
11 years 5 months ago #194213
-- url of the page with the problem -- : wiregrassrcd.com/index.php/wrcd-store
-- Joomla version -- : 2.5.28
So I just purchased the Business edition and I have followed the setup process to the letter but I am having some issues with the way my products are displays as well as modules and cart display. Basically I am trying to achieve a more professional look such as your demo pages.
1. On my product page I have tried everything to try and find where I can add text just below the product image (click here for more pictures). Also I have tried unsuccessful to add padding to the left of my product images so they will not just sit against the box surrounding the product.
2. Upon clicking the product image taking you to a more detailed page about the product I have been unable to dress up the page. Meaning, the space between the Price and the quanity as well as the "add to cart" button is quite large. Also I would like to move the main product image up as well as close the gap between the main image and the thumbnails below.
3. Lastly, upon moving to the checkout my two left modules "Shopping Cart" and "Disclaimer" still remain. This is causing a major width issue with the product information overflowing. How can I get the modules not to display? I looked at the individual modules and selected just the WRCD store page for them to display on. Do I need to setup the overall store in a different manner? Also my status bar at the top seems to be squished and I can find anywhere in the CSS to fix this.
Thank you for your help on this matter, and I am very appreciative for your support..
Last edit: 11 years 5 months ago by dmayer43.
  • Thank you received: 76
11 years 5 months ago #194215
There is error 403 on your site.
Do you have Admintools installed?
If so, try to disable "System - Admin Tools" plugin.
11 years 5 months ago #194218
ok you good to go
  • Thank you received: 14186
11 years 5 months ago #194380
1. You can edit the file "show_block_img" and add your text at the bottom and it will display below the image.
For the images position, you can reduce the "product page image height" option of the HikaShop configuration.
2. You can add custom CSS in order to position the different elements.
3. Select a menu item of the type "hikashop checkout" in the "force a menu on checkout" option of the Checkout tab of the HikaShop configuration. Then, in your modules unselect that menu item in the menu assignment option and the modules won't display on the checkout.
For the menu bar, the issue comes from the CSS:
.component-content ul li, .component-content ol li {
padding: 0;
line-height: 1.7em;
margin: 0;
in the file wiregrassrcd.com/libraries/gantry/css/joomla.css of your template.
11 years 5 months ago #194381
ok great..thank you for the response.. I will work on this and see what we can come up with.. thank you for again for taking the time to look into my issue. =)
