hot te have unique product characteristics next to
11 years 5 months ago #194309
-- Joomla version -- : 3.4
-- PHP version -- : 5.4
-- Browser(s) name and version -- : All
-- Error-message(debug-mod must be tuned on) -- : Hi,
I try to add characteristics which I have to fill in myself so I dont want them to be preconfigured as they are different for each product.
I would like to have for example the EAN code to be displayed like on the demo shop
demo.hikashop.com/index.php/en/hikashop/...cis-scott-fitzgerald
In the backend of the demo I see that the genre can be filled in manualy with each product. How can I arrange that?
I just want a set of characteristics on the right side of the image. So for each product different characteristics. Looked everywhere but can not find how to do it.
screencast.com/t/1MHAzVghj
I just want a set of characteristics on the right side of the image. So for each product different characteristics. Looked everywhere but can not find how to do it. :dry:
Last edit: 11 years 5 months ago by stof.
  • Thank you received: 14186
11 years 5 months ago #194367
In order to do that, you need to create a custom field of the table "product" and of the type "texte" via the menu Display>Custom fields. It will appear at the bottom of the product edition page so that you can enter what you want in it for each product and that will then display on the product page of the products.
