Two canonical URLs for same product page
  • Thank you received: 7
11 years 5 months ago #195167
-- Joomla version -- : 3.4.0
Hi there,
When I look at the page source, I see that I have two canonical URLs for each product page.
The actual product page is of course a canonical but then also when you add a product to the cart the URL changes to www.mysite.fr/online-shop/myproduct?popup=1 (with '?popup=1' being added to the URL due to the popup which is used). However this second URLwith '?popup=1' is also treated as a canonical.
Is there an easy way I can stop the '?popup=1' URLs beign treated as a canonical?
Thanks again
  • Thank you received: 14186
11 years 5 months ago #195622
You should disable the system SEF plugin of Joomla via the Joomla plugins manager.
It's the one adding that wrong canonical URL on your page.
11 years 5 months ago #195636
Thank you for that bit of information.
Is the "System -SEF" Joomla plugin linked to the "Search Engine Friendly URL's" in the site settings? Can I disable "System - SEF" without it affecting my "Search Engine Friendly URL's" option in site settings?
Thanks again
11 years 5 months ago #195662
Yes, that should not be a problem.
