Title/header not showing for product listing
11 years 4 months ago #197112
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.4
-- Browser(s) name and version -- : any
How can get the tile to display for the product listing when you click on the category or sub category? I also notice the hikashop demo doesn't have a title for the product listing.
  • Thank you received: 14186
11 years 4 months ago #197122
Turn on the "show component heading" option of your menu item when you edit it via the joomla menu manager.
The following user(s) said Thank You: nokki00
11 years 3 months ago #202153
Yes Nicholas, but what if I want show the Title when using the Category Module?
There is no "Show Component Heading " option when using the module!
Thanking you in anticipation.
Jay
The following user(s) said Thank You: Xavier
11 years 3 months ago #202171
Yes indeed, there is no options like that for the modules.
But the modules are associated/using a module so you have to select the desired menu in the "menu" option of your module.
