Images for each product property nog showing
11 years 4 months ago #197147
-- url of the page with the problem -- : verfzone.be/varia/product/afplak-tape-geel-25m-x-2-4cm
-- Joomla version -- : 3
On my site i have a product with several different properties( for example verfzone.be/varia/product/afplak-tape-geel-25m-x-2-4cm ) I set an image for each differtent propertie but they are not showing when choosing the property in the dropdown list.
Does anyone have a sollution for this problem?
  • Thank you received: 14186
11 years 4 months ago #197157
This comes from some customization of the page done by yourself or your template which forces the size of the image of the variants to 0.
Add such CSS and that should avoid the problem:
.hikashop_product_main_image_subdiv img{ width : auto !important; height: auto ! important; }
11 years 4 months ago #197304
Thank you for your response, i am new to joomla. In which css file schould I add this?
11 years 4 months ago #197311
Here is a documentation page which explains how to add such CSS code:
Time to create page: 0.188 seconds
