Related Products Module Before Description
11 years 4 months ago #197737
-- url of the page with the problem -- : knvvl.micpoint.nl
-- Joomla version -- : 3.4.1
I would like to display the module related products before the description of the product instead of under it.
I tried modifying the product-show view but was not able.
11 years 4 months ago #197740
Via the menu Display > Views, edit the view "product / show_default" and add the code:
<?php echo JHTML::_('content.prepare','{loadmodule XX}'); ?>
Where XX is the id of the related products module, before:
<div id="hikashop_product_description_main" class="hikashop_product_description_main">
11 years 4 months ago #197983
It's not working.
This is de code i have
<?php
 * @version	2.3.5
 * @author	hikashop.com
 * @copyright	(C) 2010-2015 HIKARI SOFTWARE. All rights reserved.
?><div id="hikashop_product_top_part" class="hikashop_product_top_part">
<?php
	$this->setLayout('show_block_social');
	echo $this->loadTemplate();
</div>
<?php if(HIKASHOP_RESPONSIVE){ ?>
	<div class="<?php echo HK_GRID_ROW; ?>">
<?php } ?>
<div id="hikashop_product_left_part" class="hikashop_product_left_part <?php echo HK_GRID_COL_6; ?>">
	<?php
	if(!empty($this->element->extraData->leftBegin)) { echo implode("\r\n",$this->element->extraData->leftBegin); }
	$this->row = & $this->element;
	$this->setLayout('show_block_img');
	if(!empty($this->element->extraData->leftEnd)) { echo implode("\r\n",$this->element->extraData->leftEnd); }
</div>
<div id="hikashop_product_right_part" class="hikashop_product_right_part <?php echo HK_GRID_COL_6; ?>">
	<?php
	if(!empty($this->element->extraData->rightBegin))
		echo implode("\r\n",$this->element->extraData->rightBegin);
<?php if(!empty($this->element->extraData->topBegin)) { echo implode("\r\n",$this->element->extraData->topBegin); } ?>
  <h3>
		<span id="hikashop_product_name_main" class="hikashop_product_name_main">
			<?php
			if (hikashop_getCID('product_id')!=$this->element->product_id && isset ($this->element->main->product_name))
				echo $this->element->main->product_name;
			else
				echo $this->element->product_name;
		</span>
		<?php if ($this->config->get('show_code')) { ?>
		<?php } ?>
	</h3>
<?php if(!empty($this->element->extraData->topEnd)) { echo implode("\r\n",$this->element->extraData->topEnd); } ?>
	<div id="hikashop_product_vote_mini" class="hikashop_product_vote_mini">
		<?php
		$config =& hikashop_config();
		if($this->params->get('show_vote_product') == '-1'){
			$this->params->set('show_vote_product',$config->get('show_vote_product'));
		if($this->params->get('show_vote_product')){
			$js = '';
			$this->params->set('vote_type','product');
			if(isset($this->element->main)){
				$product_id = $this->element->main->product_id;
			}else{
				$product_id = $this->element->product_id;
			$this->params->set('vote_ref_id',$product_id);
			echo hikashop_getLayout('vote', 'mini', $this->params, $js);
	</div>
	<span id="hikashop_product_price_main" class="hikashop_product_price_main">
		<?php
		if ($this->params->get('show_price')) {
	<?php
	if(!empty($this->fields)){
		$this->setLayout('show_block_custom_main');
	if(HIKASHOP_J30) {
		$this->setLayout('show_block_tags');
	</span>
<?php
echo preg_replace('#<hr *id="system-readmore" */>.*#is','',$this->row->product_description);
Echo "<a href=#omschrijving>Meer informatie</a>"
?><br />
	<?php
	if(!empty($this->element->extraData->rightMiddle))
		echo implode("\r\n",$this->element->extraData->rightMiddle);
	<?php
		$this->setLayout('show_block_dimensions');
	?><br />
	<?php
	if($this->params->get('characteristic_display') != 'list') {
		$this->setLayout('show_block_characteristic');
		<br />
	<?php
	$form = ',0';
	if (!$this->config->get('ajax_add_to_cart', 1)) {
		$form = ',\'hikashop_product_form\'';
	if (hikashop_level(1) && !empty ($this->element->options)) {
		<div id="hikashop_product_options" class="hikashop_product_options">
			<?php
			$this->setLayout('option');
		</div>
		<br />
		<?php
		if ($this->config->get('redirect_url_after_add_cart', 'stay_if_cart') == 'ask_user') {
			<input type="hidden" name="popup" value="1"/>
		<?php
	if (!$this->params->get('catalogue') && ($this->config->get('display_add_to_cart_for_free_products') || !empty ($this->element->prices))) {
		if (!empty ($this->itemFields)) {
			<?php
			$this->setLayout('show_block_custom_item');
	$this->formName = $form;
	if($this->params->get('show_price')){ ?>
		<span id="hikashop_product_price_with_options_main" class="hikashop_product_price_with_options_main">
		</span>
	<?php }
	if(empty ($this->element->characteristics) || $this->params->get('characteristic_display')!='list'){ ?>
		<div id="hikashop_product_quantity_main" class="hikashop_product_quantity_main">
			<?php
			$this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form\')){ return hikashopModifyQuantity(\'' . $this->row->product_id . '\',field,1' . $form . ',\'cart\'); } else { return false; }';
			$this->setLayout('quantity');
		</div>
	<?php } ?>
	<div id="hikashop_product_contact_main" class="hikashop_product_contact_main">
		<?php
		$contact = $this->config->get('product_contact',0);
		if (hikashop_level(1) && ($contact == 2 || ($contact == 1 && !empty ($this->element->product_contact)))) {
			$empty = '';
			$params = new HikaParameter($empty);
			global $Itemid;
			$url_itemid='';
			if(!empty($Itemid)){
				$url_itemid='&Itemid='.$Itemid;
			echo $this->cart->displayButton(JText :: _('CONTACT_US_FOR_INFO'), 'contact_us', $params, hikashop_completeLink('product&task=contact&cid=' . $this->element->product_id.$url_itemid), 'window.location=\'' . hikashop_completeLink('product&task=contact&cid=' . $this->element->product_id.$url_itemid) . '\';return false;');
	</div>
	<span id="hikashop_product_id_main" class="hikashop_product_id_main">
		<input type="hidden" name="product_id" value="<?php echo $this->element->product_id; ?>" />
	</span>
	<?php
	if(!empty($this->element->extraData->rightEnd))
		echo implode("\r\n",$this->element->extraData->rightEnd);
</div>
	</div>
<div id="hikashop_product_bottom_part" class="hikashop_product_bottom_part">
	<?php
	if(!empty($this->element->extraData->bottomBegin))
		echo implode("\r\n",$this->element->extraData->bottomBegin);
	?> <?php } ?><?php echo JHTML::_('content.prepare','{loadmodule hikashop_submodules}'); ?>
		<?php
		echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description));
	</div>
	<span id="hikashop_product_url_main" class="hikashop_product_url_main">
		<?php
		if (!empty ($this->element->product_url)) {
			echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>');
	</span>
	<?php
	$this->setLayout('show_block_product_files');
	<?php
	if(!empty($this->element->extraData->bottomMiddle))
		echo implode("\r\n",$this->element->extraData->bottomMiddle);
	<?php
	if(!empty($this->element->extraData->bottomEnd))
		echo implode("\r\n",$this->element->extraData->bottomEnd);
</div>
Last edit: 11 years 4 months ago by Xavier. Reason: Use of [code] ... [/code] tags.
11 years 4 months ago #198002
Nothing is displayed, or the tag is displayed but not replaced ?
I think that "hikashop_submodules" is not a valid value, here is the Joomla documentation about the loadmodule and loadposition features:
docs.joomla.org/How_do_you_put_a_module_inside_an_article%3F
ps: the plugin "Content - Load Modules" must be published.
