problem adding to cart
  • Thank you received: 4
11 years 3 months ago #202134
-- Joomla version -- : 2.5.28
-- PHP version -- : 5.5.37
-- Browser(s) name and version -- : any
-- Error-message(debug-mod must be tuned on) -- : Notice: Trying to get property of non-object in administrator/components/com_hikashop/classes/cart.php on line 317
i have a big problem on the site. When i go to there and add to cart, i have to add items 3 times to cart, before they get into for first item.
only error i see when doing debuging is
i have tried both with our custom template and the default beez20 template, and it does the same.
i have removed all other errors i was seeing on page, so no idea what is causing it.
any suggestions or help on how to fix this problem would be good
11 years 3 months ago #202147
Please give us the corresponding lines arround the one given in the php error message.
Do you have any cache enabled on your website ?
11 years 3 months ago #202412
from line 310
		JRequest::setVar('new_'.$cart_id,$cart->cart_id);
		JPluginHelper::importPlugin( 'hikashop' );
		$dispatcher = JDispatcher::getInstance();
		$do = true;
		$dispatcher->trigger( 'onBeforeCartUpdate', array(&$this, &$cart, &$product_id, &$quantity, &$add, &$type,&$resetCartWhenUpdate,&$force,&$do) );
		if (!$do) return false;
		if(!$app->isAdmin() && $cart->cart_id){
			$app->setUserState(HIKASHOP_COMPONENT.'.'.$cart_id, $this->cart->cart_id);
317 is $app->setUserState(HIKASHOP_COMPONENT.'.'.$cart_id, $this->cart->cart_id);
$cart_id = $this->cart_type.'_id'; is defined in 278
if i look in the source of the lastest version from the site, it is the same as in that file.
i normaly do have cache on, but have turned off and cleared out the site to test if it was that, but still makes same error
11 years 3 months ago #202415
Ecommerce systems are not compatible with cache, so cache must be disabled in Joomla settings, Joomla cache plugin and potentially cache option in template.
Please send us backend and FTP access to your website via our contact form in order to debug that issue direclty on your website. Don't forget to give the url to that topic in the message.
11 years 3 months ago #202527
I have sendt you the info on the contact form
you know, that Joomla has flags you can set, that disable cache for one page/module ? so if you just set this info on everything that is dynmic of your parts, cache can be working fine.
And i have several other pages i help with their Joomla sites wiht Hikashop which runs cache on without any problems, so it really not a cache problems also showed by cache being disabled and the problem still persist
Last edit: 11 years 3 months ago by jesper.
11 years 3 months ago #202535
The cart is correctly updated, but after we press F5 to refresh the whole page.
Without a backend access we can't see your settings, are you using the Ajax functionality to refresh the cart ?
(in Configuration > Main > Advanced settings)
If not, you maybe have a third extension which avoid the page refresh to update the cart informations.
11 years 2 months ago #203215
I have resubmitted the backend login information by the contact form.
problem is still not solved
11 years 2 months ago #203297
I got backend access but I do not have FTP access like Xavier asked.
But about your issue, can you please modify the line 317 from
into
$app->setUserState(HIKASHOP_COMPONENT.'.'.$cart_id, $cart->cart_id);
It should fix the warning problem and I hope, the rest of your issue.
If not, please provide us the FTP access so we will be able to see and perform directly some tests.
The following user(s) said Thank You: jesper
11 years 2 months ago #204851
I have been testing alot on this and found out it was a plugin special for this page that does the problem.
the code that gives the error is
$cartClass = hikashop_get('class.cart');
$cart = $cartClass->loadFullCart();
when i remove that code, everything works fine.
The code for this have been found on www.hikashop.com/support/documentation/6...r-documentation.html
what this plugin does is prevent items from different categories to be added to cart at the same time.
11 years 2 months ago #205120
Jerome any idea on this ?
11 years 2 months ago #205123
Do you now which plugin is causing that issue ? Please give us more details on this.
If you don't know which of them is causing this, please try to disable them one by one.
11 years 2 months ago #205240
Hi Xaviar,
yes as i wrote its a custom plugin to prevent items from selected main categories not to be added in cart as same time as from the other main categories.
the code is as following
function onBeforeCartUpdate(&$a, &$cart, $product_id, $quantity, $add, $type,$resetCartWhenUpdate,$force,&$do) {
		if ($cart->cart_id && $quantity > 0) {
            JFactory::getSession()->set('bbhika', "");
			$pluginsClass = hikashop_get('class.plugins');
			$plugin = $pluginsClass->getByName('hikashop','bedrebad');
			$state = false;
			$mainkat = explode(",",$plugin->params['mainkat']);
			$productClass = hikashop_get('class.product');
			$product=$productClass->get($product_id);
			$inkat = $this->maincat($product_id,$mainkat);
			$cc = $cartClass->loadFullCart();
			foreach($cc as $aa ) {
				$v_kat = $this->maincat($aa->product_id,$mainkat);
				if ($v_kat !== $inkat) $state = true;
			if ($state) {
				$do = false; //Stop for at ligge varer i kurven
				JFactory::getApplication()->enqueueMessage(JText::_('HIKASHOP_BEDREBAD_ERROR'),'error');
				JFactory::getSession()->set('bbhika', "error");
	function maincat($pid,$parrent) {
		$state = false;
		$database = JFactory::getDBO();
		$database->setQuery('SELECT category_id FROM '.hikashop_table('product_category').' WHERE product_id = '.$pid.'');
		$ret = $database->loadObjectList();
		foreach ($ret as $r) $id[] = $r->category_id;
		foreach ($id as $i)
		do {
			if (in_array($i,$parrent)) {
				$state = true;
				break;
			$database->setQuery('SELECT category_parent_id FROM '.hikashop_table('category').' WHERE category_id = '.$i.'');
			$ret2 = $database->loadObject();
			if (in_array($ret2->category_parent_id,$parrent)) {
				$state = true;
				break;
			$i = $ret2->category_parent_id;
		} while ($ret2->category_parent_id != 0);
		return $state;
and the lines that give the problems are
11 years 2 months ago #205671
So Xavier any help you can give me ?
11 years 2 months ago #205714
Can you give us :
- A temporary FTP access to your website so that we can directly check your code
- Your custom plugin name (file location)
- Step by step instructions of how to reproduce your issue
Through our contact form so that we can directly test and fix it : www.hikashop.com/support/contact-us.html
11 years 2 months ago #205833
Hi Mohamed,
information has been send to you.
11 years 1 month ago #205969
I can see in the plugin that you changed from loadFullCart() function to the get() one, does that solve the issue ?
In frontend when adding a product it is correctly added to the cart, there is just the page to refresh so maybe you will have to disable the option to use ajax on add to cart buttons, or you have some cache enabled.
ps: I was not able to connect to backend, I tried the two passwords (old and new one) and I've been banned ;)
11 years 1 month ago #205975
no it doesn't matter if i use the one or the other, gives same problem.
the plugin was disabled, thats why it worked... i have reenabled it and i have removed your ban from the firewall
11 years 1 month ago #205995
I still have issues to reach the backend:
take.ms/97M1U
But as you said that you reenabled the plugin I tried again and it seems to be working pretty fine.
If you disabled it, please check the backend access in order to help you.
11 years 1 month ago #206127
if you just press the button you should get to the control panel without problems... i will look why it gives that error though.
11 years 1 month ago #206173
When clicking on the button, I get redirected to the login page.
I just tried again, and I can definitively not reach your backend. The password seems to be no more working so autobanned a second time.
