problem adding to cart
  • Thank you received: 4
11 years 1 month ago #206599
disabled the autoban as it is a test site... try now
11 years 1 month ago #206613
Still banned message after the htaccess password.
11 years 1 month ago #206705
removed the script that autobans at it is just a testserver ;)
its bb.test..... you use right ?
11 years 1 month ago #206767
My bad, I was using an older access. So ok I have been able to reach the backend of the test domain, and reproduced the error.
It seem to be coming indeed from the cart class, strange because when we check the value of the $do variable after calling the trigger "onBeforeCartUpdate" in the cart class the value of $do is well "true" so the product should be added in the cart...
I will do further investigation, I have no clues for the moment, keep you informed.
11 years 1 month ago #206773
Ok, problem solved, you have to use the function "initCart()" of the cart class after a get() or a loadFullCart().
This allow to make the cart usable back.
11 years 1 month ago #206889
thanx that helped me fix that problem.
